My 97 aspire had been leaking oil all over the valve cover from the PCV valve, and the filler cap as well for a while. It was never much, until I just changed the oil (I let it go a little long
) with 5w30. Now its puking quite a bit on the valve cover. Enough for it to get visibly wet all over the top of it in my 20 minute drive to work.
I figure, ok, PCV valve might be clogged. $3 for a new one, Id rather pay that than even check the old one. Still leaking from the filler cap, but not so much (seemingly, but I havent driven it beyond the 10 minute drive home form the parts store) from the PCV. It is a better fit on the grommet though, which probably helps.
I pull the vacuum line going to the PCV while running, and it is pulling vacuum, and the valve it pushing pressure out.
I pull the filler cap while its running, and it starts blowing smokey fumes out. The plume reaches about 6" high before it begins to dissapate, but the pressure from it only makes it about half of that before becoming ineffective. When the gas is pressed, a slight vacuum ensues, as it should. Obviously, I cant test this under load though.
My questions:
How much blow by, if any, is normal?
Should it be smokey?
Should my filler cap have a rubber gasket? It doesnt have one at all.
![Frown](https://fordfestiva.com/forums/core/images/smilies//frown.gif)
My questions:
