Great! Let us know when she is up and running. While you are waiting, remove your intake hose and make sure your VAF door moves freely. Your fuel pump will not run if the VAF is not working.
Where is the starter located 89 Festiva EFI Auto trans
Originally posted by gunnerw View PostOK you must be talking about the air intake and I assume is the Air Flow?Last edited by dalebwilson; 08-12-2014, 04:20 AM."Fred" 93 Festiva L B6-ME Swap
Ok, I replaced the fuel pump (gotta love that access panel) Again tried to start. It will crank (also a new starter) it does crank and will act like it want to fire but nothing. I tried the jump the two pins again with the paper clip and now i get no sound, no clicking. Is it my fuel pump relay? I check the out side of the fuel filter and cranked the starter. I have no fuel coming out. I dont hear the fuel pump running either. That is what make me think fuel pump relay.Last edited by gunnerw; 08-22-2014, 09:14 AM.
Pull the side panel on the driver's side rear. There should be an fuel shut- off relay there in case of an accident. Reset the button and see if the fuel pump runs then.Chuck
91 GL -Ol' Rusty
93 GL - Lil Red
91 L - Tweetystiva
I found the fuel inertia shut off. The fuel pump still isn't running. I don't seem to have any power to the fuel pump. Anyone know any next steps? I checked the owners manual and there doesn't appear to be a fuse for the fuel system. Any more ideas?
I replaced the EGI fusable link with a hard fuse. The VAF door does swing freely but i don't know about the VAF fuel pump switch. I still think it might be the fuel relay because when i jump the two leads using a paper clip I am not getting any clicks. Ill check the power from the pump back. Is there any procedure to check the VAF fuel switch?
As always i appreciate all the help
Gunner
Did you check the fuel pump switch in the VAF for continuity? If that checks good, replace the fuel pump relay under the drivers side dash.Last edited by dalebwilson; 08-24-2014, 05:40 PM."Fred" 93 Festiva L B6-ME Swap
