I am doing the inner tie rods, for the fist time, as the right inner failed safety inspection.
How do you tell a bad inner tie rod? Is it going to be loose and have play in it? Haynes, as usual, is not much help.
I have to remove the boot and get to the ...what is it ...a U joint?? I haven't seen what is under the boot yet, thought i'd ask and maybe get some pointers on doing it, before I delve in.
I was searching around, but not finding what I needed, but I did find out that the inners of the 1988/89 yrs are different from the 90/93 yrs!
Carefull! I found some McPart stores had the same part number for all yrs and it wasn't for 88/89 yrs!
