Since my rebuild I have been getting terrible gas mileage. About 24mpg. I knew swapping to a b6 would lower it some but almost 35% tells me something isn't right. I've checked the compression and im at 160 across all cylinders. The wide band normally reads 14ish during cruising. It will sometimes drop to the 10s if I let off the gas for a second or push on it just a little it will go back to the 14s. I haven't been hot rodding it around. I looked to see if there were any codes this evening and it flashed 1 8 and 17. I reset the ecu by leaving it unplugged for 5 minutes and it hasn't thrown any new ones yet was I in a sort of limp mode?
I changed so much at once I don't know where to start looking. New engine, I have new wheels and tires. Slightly larger 165 65r 14s. Aspire front brakes. Ive read that after a fresh rebuild it takes a while to get peak mpg. Im about 600 miles into the rebuild.
scared to put my foot in it! I don't need another 13mpg vehicle lol
