I have a 91 L 5 speed that is completely stock aside from the funtop canvas roof. Prior to my ownership someone cut the harness wiring for the radiator cooling fan and put a switch on the dash from the battery that goes directly to the cooling fan. I am curious to know if there is a relay somewhere either in the engine bay or under the dash that may be bad that would cause someone to create a manual bypass like this. I have a donor car to get another fan (a mechanic friend suggested the fan may have shorted a few windings causing me to start going through switches recently) and that part of the harness. I noticed when investigating this problem originally that there is a 20Amp fuse in the fuse block in the dash for the cooling fan, but it appears to be in working order (since I pulled it out to check its condition). I want to fix this correctly when I fix it this time if at all possible since it is my current daily and only running vehicle for the moment. Thanks in advance for any help regarding this matter
