I have an 89 Fuel Injected Festiva with AT. I purchased it a couple of weeks ago. Initially it did start and ran for about 30 seconds. Since then I have been chasing fuel deliver problems. It wants to start. I little squirt of starting fluid and it will fire. Here is what I have done to date. I have replaced the starter. I have replaced the fuel pump and screen. I have also replaced the fuel pump relay and have checked the continuity at the VAF and when I swing the door open I do have continuity. It had very little gas in it when I bought it and I have added about 3 gallons. I am not getting any fuel to the engine through the fuel line. I am assuming the top fuel line is the inlet and the bottom is the return line. I really can't hear the fuel pump running but when I open the gas cap after cranking for awhile there is pressure in the tank. I threw a volt meter on the fuel pump wires (green/white and the other is yellow) and I get a fluctuating voltage as high a 4 volts. I am baffled. I guess it is possible the new fuel filter is clogged with debris that was in the lines. The car has had one owner and has 132K miles on it. It did sit for a year without running.
Anyone have any ideas?????????
