Hi guys
Have been running 80W gear oil for the last few thousand miles off the advice of a mechanic at the time, it's okay in winter but terrible in the hotter weather - 1st/2nd issues engaging, all started with the new oil so I'm 99% sure that's the problem.
So I bought some overkill (expensive) 100% Synthetic ATF today and I'm ready to go.
One question:
Is a flush required or recommended prior to the new stuff going in? Since its a big difference in consistency.
And if so, can I just use the ATF as I have way more than I need for the job.
Or no flush required, just fill and go?
Thanks in advance.
One question:
Thanks in advance.
