I'm absolutely sure someone knows the answer to my question, so here goes: My (cars) temperature gauge mostly reads below the lowest normal reading so I decided to install an aftermarket gauge. Then read where the computer reads the temperature to adjust the mixture, etc. So if I bypass the electrical sensor with a mechanical probe, will that mess with my computer deciding when to lean or rich the mixture? Also, same with adding an oil pressure gauge?
Thank you for helping.
