GF was gifted a 93 after her last one was crashed by a drunk kid next door.
1993 FI 5 speed car no power steering timing, timing belt all good and spot on.
This thing has been a pain in the butt from day one, replaced fuel pump and filter, O2 sensor, oil and filter, air filter last couple days a new TPS, which I set with my multi meter, and an ignition module.
I get no change in symptoms!
Here's the issue: starts and runs well to warm up point ( about 3 to 5 minutes) then starts idling terrible and you can't get it to break idle with out stalling!
Any movement out of the throttle idle position and it craps out. Searched for Vacuum leaks didn't find any and can't hear them either Vacuum gauge running 21 when everything is smooth.
Last night, after the ignition module install and once again making sure the TPS was set right, it ran great at start up and I thought I had it fixed!
Ran the usuall few minutes and started the poor idle routine. Played with the air bleed but no change in idle then noticed the VAF sounded like it had a bunch of Hornets in it, A real buzzing noise.
Wasn't doing this at start up but as soon as I noticed the poor idle I also heard this buzzing noise, could this be a bad VAF?
I do have a "clean" VAF just purchased, I made a hasty install last week and it wouldn't run at all ( forgot to un plug battery before trying to start it) Plan to go pull it from my storage this afternoon after work and re try it.
Mean while anyone had the same problem? Looking for an answer fast the GF can't handle not having a ride.
