So you used the bearings already on the rods?
Taking A Peak At What's Inside a B3
Bhearts...If I were building a complete engine, I would have certainly replaced everything in the bottom end including the rod bearings. While driving this $500 car 200 miles per day with 280K on the odometer, my intention here was simply to determine the cause of the oil consumption and low vacuum and repair at the lowest cost.Originally posted by bhearts View PostI didn't know you could do that. Hmm."Fred" 93 Festiva L B6-ME Swap
From looking at the pics in posting #13 am I correct in assuming that you pulled the pistons and worked on the block while the block was still in the car?Originally posted by dalebwilson View PostBhearts...If I were building a complete engine, I would have certainly replaced everything in the bottom end including the rod bearings. While driving this $500 car 200 miles per day with 280K on the odometer, my intention here was simply to determine the cause of the oil consumption and low vacuum and repair at the lowest cost.
OK, I reread original thread.Last edited by bolokid; 10-14-2014, 11:53 AM.
I might have to consider doing this on a few of the engines I have. Didn't realize that the cost was so low.The Festiva Store
No worries Bhearts, I didn't take it that way. Good luck for your future rebuild.Originally posted by bhearts View PostI'm not hating. I just had no idea they could be reused. I've never built an engine personally. But I like learning what I can before I dive in."Fred" 93 Festiva L B6-ME Swap
Gotta WalMart near you?Originally posted by Fordverde View PostWhat the hell is in that stuff Berryman's Chem-Dip???? Sweet Jesus!!! need to get me some of that juice!!
Absolutely. The costs are minimal but the results can be quite substantial. One reason I posted this thread was to give an alternative to those that do not wish to pull and replace their engine. The bottom end of the B3's are robust enough that normally the rings wear before other moving parts. The work that I did can be easily done in a half to one full day. The only specialized tools needed are a torque wrench, feeler gauge and a ring compressor.Originally posted by nonamekid View PostI might have to consider doing this on a few of the engines I have. Didn't realize that the cost was so low."Fred" 93 Festiva L B6-ME Swap
I thought I would post an update at the 500 mile break in period after the new piston rings were installed.
-Normal vacuum at idle has increased from 20hg to 22hg and is very smooth. (Ignition timing set at -10BTDC)
-The B3 continues to gain noticeable power each day. (I did install an Aspire cam and rockers while the head was off)
-On my normal 100 mile commute, I am averaging 50 mpg's. (This is combined mountain and highway driving) Before the new rings were installed, I was averaging 42-45 mpg's.
-Engine oil remains clear and no smoke from the exhaust. There is no noticeable oil consumption. (Per the recommended interval, I plan on changing the break in oil and filter this weekend)
Very pleased with the inexpensive fix.Last edited by dalebwilson; 10-17-2014, 07:28 AM."Fred" 93 Festiva L B6-ME Swap
