Bleeding brakes issue
  • Bleeding brakes issue
    Ever since i did my aspire swap i havent been able to get the brakes to feel good. Bled and bled, no air. They work but the pedal is soft and has no feel at all. Just mediocre braking. New everything. No visible leaks. Wondering if the master cyl i got is bum
    if you hold the pedal down does it slowly creep towards the floor? if it does, then the master may be bad.
      No they hold pressure its just thats there isnt much bite. I realize it doesnt have big brembos but it feels worse then they did to begin with
        Did you use the Aspire master cyl? I think unless you use the Aspire one the brakes will feel a bit spongy. I am pretty sure that the Aspire master is larger because the brakes are larger on the Aspire.
          Its a new festy one. I may upgrade it. Gonna go escort if i do. Cheaper and bigger
            Looks like my prop valve is leaking from the side cover thing. Probably a long ago discontinued part
              Ok, I just saw your post. I have a parts car in my back yard. ill pull the prop valve and look at it. if it look sin good nick ill send to ya.
                I've heard the miata master/booster works good and takes up less space.
                91GL BP/F3A with boost
                  I have stock festi brakes on mine and they feel that way but with a hard pedal. No modulation feel. Stops pretty good though. I have had a bunch of nissan trucks and they seemed to be like that too.
                    That would be cool. I use paypal. Just would be nice to go for the brakes and not question if im gonna stop
                      Just pulled from the car. all of the fittings are loose I just put them back in just in case any fluid tries to leak out.
                        Pm me a price
                          pm sent
