trans fluid ?
  • trans fluid ?
    dextron II is whats called for I believe. anyway I was wondering if theres any pre prep and/or additive
    anybodys used with good results. any synthetic brand out there?
    its a 5 speed man.
    I'm going to drain and refill with fresh this week end.
    admit nothing - deny everything - make accusations
    Everybody either disagrees on this or just sticks ATF in it and forgets about it from what I've read.
    I like Mobil 1 Euro Spec. It's motor oil. It works just fine. And it's synthetic. It's also a 0w weight so it's good for cold weather, if that's a concern.
      ATF, is correct, Nothing to do but drain, refill!
      I hear syncromesh is pretty awesome. I havent used it yet. I just use ATF.
      Dan
        I have synchromesh in mine. It shifts smoother than before.
        Jerry
        Team Lightning
        Owner of Team Lightning
        93 L Lightning. BP
          +1 on Pennzoil synchromesh. That's what I have been running for a while.
            I use Royal Purple Max ATF, its speced for MTX also.
            '93 Green L - ' Tiva
