Got a 93 manual festi with about 156k on it. Last night I was driving down the road hit the brakes at a stop sing and had pressure then lost it.....had to pull the emergency brake to stop......took a good amount of strength to not lock it up and the scare took at least 5 years off my life. Anyway I found out that it is the front drivers side brake line that busted through. It is right past the firewall on the part that is still metal line (before it goes to the flex line)....Where in the world can I find one of the metal lines that runs from the brake distributor (where it separated left from right sides) to the the flex line?
Thanks
Thanks
Poverty produces creativity
