Oil leaks And leaks
  • Oil leaks And leaks
    So my valve cover somehow always leaks, (lasts about 2 months) And I changed my pcv valve. still leaks. Is there any special VC gasket we could use? instead of the $20 NAPA one. I was also thinking bout putting VC studs and a oil catch can. Also how common do cam seals leak on these engines? Thanks (mazda bp turbo engine btw)
    Are you still using the vc vent? If so your pressuring your motor under boost. And that will make leaks
    -Greg
    Redneck Engineer
    FOTY - '09
      Yeah I got a little breather filter on it. You running a catch can?
