Speedometer Sensor Broken
  • Speedometer Sensor Broken
    Hi guys, got a question for you.
    Is there an easy way to get the speedometer sensor in the transmission out? This is the 2nd one I've had to do and it's been an absolute nightmare both times. the one in my new G-Series is pretty well busted out now, Do I have to go all the way into the transmission again just to get this piece out and replace it?
    I will post pictures in a minute of what's going on.
    Car #789
    Sponsors: Williams American Construction, Dewaynes Tire service, Roofing Supply Group
    1992 Festiva L - BP Swapped, Aspire Swapped, Rally America Sanctioned.
    1993 Festiva GL - 4sp Automatic and the bluest car i've ever seen...
    http://www.facebook.com/warally
    Car #789
      10mm bolt appears to have been sheared off. if you can get that out the unit should lift out in one piece.
