festy has aspire swap and it needs ball joints. do I order for a festy or aspire part? that is the lower control arm/ball joint combo piece.
ball joint ?
Aspire control arm/ball joint for Aspire swap. Different than the festy armDan
I beg to differ on that. The Festiva lower control arm should be used. It's the Aspire outer tie rod ends that are required. I believe the Aspire arms are longer than the Festiva's and would cause issues with the axles. I use Festiva arms on my Aspire swapped car.Last edited by fastivaca; 11-06-2014, 10:39 PM.Ian
Good catch on the correction. You use the Aspire LCAs when you do the Capri front knuckle/brake swap.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Originally posted by drddan View PostAspire control arm/ball joint for Aspire swap. Different than the festy armOriginally posted by fastivaca View PostI beg to differ on that. The Festiva lower control arm should be used. It's the Aspire outer tie rod ends that are required. I believe the Aspire arms are longer than the Festiva's and would cause issues with the axles. I use Festiva arms on my Aspire swapped car.Last edited by drddan; 11-07-2014, 04:46 AM.Dan
