Hey everyone. I went to start my Festiva this morning and it fired up right away. When I let off the key it just died isntantly like I had turned the key to off. Didn't bog or anything. When I tried again I held the key for a couple seconds in start and it ran fine until I let off the key again and it died instantly just like before . Anyone have this issue and/or suggestions?
Fires then dies instantly
Thank you for the help but hitting the report button in the future will work better since it will notify the staff members and we can move the threadOriginally posted by tooldude View PostThis belongs in repair.
Thread movedLast edited by Damkid; 11-23-2014, 04:58 PM.
Sounds like the problem could be related to the fuel pump relay and/or the VAF connection to it.
The fuel pump is triggered to operate when the switch is in the start position but the trigger for the
fuel pump to continue operating when the switch is in the on position comes from the VAF which must sense
air moving through it into the intake manifold to let the fuel pump know that it should continue to run.
Check the plug connecting the wires to the VAF. It could also be a ground wire problem.
Are you located where road salt is present?
Check this thread http://www.fordfestiva.com/forums/sh...uel+pump+relay
tooldude and others posted lots of good info about how to do the fuel pump test there.Last edited by 1990new; 11-23-2014, 06:26 PM.
I agree it sounds just like the VAF is unplugged, or a poor connection as 1990new said
X3Originally posted by Damkid View PostI agree it sounds just like the VAF is unplugged, or a poor connection as 1990new saidContact me for information about Festiva Madness!
With an unplugged VAF it will run for about 2 seconds after you let go of the key. At least when my VAF started acting up, that is what it did. Even unplugged it would run for 2 seconds before shutting off.
It sounds like a bad ignition switch.Last edited by nonamekid; 11-23-2014, 11:10 PM.The Festiva Store
Ignition switches do go bad and it could be the problem. They usually go bad gradually and you get warnings that they are going bad...like intermittent drop in power connection of
the electrical components that must have the switch on to operate. For example, turn your wipers on and see if they quit when you return the key from start to on.
1992Festiva... have you had any problems like that that seem to come and then go away?
Did you perhaps accidentally dump a beverage on the plastic shroud behind the steering wheel recently?
We need more info..Last edited by 1990new; 11-23-2014, 11:33 PM.
Does your car have a Carb or EFI ?Originally posted by 1992Festiva View PostHey everyone. I went to start my Festiva this morning and it fired up right away. When I let off the key it just died isntantly like I had turned the key to off. Didn't bog or anything. When I tried again I held the key for a couple seconds in start and it ran fine until I let off the key again and it died instantly just like before . Anyone have this issue and/or suggestions?Some people like to read fiction,I prefer to read repair manuals. Weird I know-
HeyOriginally posted by 1992Festiva View PostHeyLast edited by drddan; 11-24-2014, 03:46 AM.Dan
If its a 1992 it would be fuel injected?
A quick thing to try is spraying WD-40 or contact cleaner into the ignition keyhole.
Put the key in and out and turn it on and off to work it around a bit.
The key is turned against a spring to START to engage the starter
then springs back to ON for running so the change in position might be causing the problem?Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Oh missed that my bad-Originally posted by WmWatt View PostIf its a 1992 it would be fuel injected?
then springs back to ON for running so the change in position might be causing the problem?Last edited by nitrofarm; 11-24-2014, 04:33 PM.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
