Another oil leak question
  • Another oil leak question
    Hello gentleman, I have a festy with 305,XXX miles and it has sprang a significant oil leak. I haven't had a chance to check it out, but I do know that oil is leaking down onto the belts causing the belts to slip. Any ideas where this leak could be? Thanks in advance!
    Front crankshaft seal or camshaft seal.
      If the original crank and cam seals are still there, they will be hard as a rock and splinter like glass when you pop them out. At 300K and if you plan on keeping the car, this is a great time to replace the water pump/o-ring, tensioner/spring and timing belt. You are already there and it makes no sense to put old parts back together. Just my 2 cents.
