I bought my Festiva with an inoperative horn. Today, while installing new headlamp assemblies, I found the power wire that should connect to the horn, a red and green wire that has power when either horn button is pressed, just hanging, connected to nothing, behind and below the drivers side headlamp. No horn was to be found in the general vicinity. Further complicating matters, my wiring schematic shows the horn located on the passenger side, well outside of the reach of the main power wire.
After fighting a slightly bent core support putting the new drivers side headlamp in, it became clear my car was in an accident at some point in its life. I suspect that whoever did the collision repair reassembled the car without the horn. Still, I'd like to know the proper location so I can see if a horn is actually there. Does anyone know where the horn normally lives on a '93 Festiva? Thanks in advance guys.
