No Start Condition
  • No Start Condition
    While i was working on my 91 festiva, b3 sohc, fuel injected, (i was removing the seats, back carpeting, passenger seat and shifter covers, didn't mess with the engine or wiring at all) When i went to start it, it no longer started. My first thought was i hit the inertia switch removing the back seat, but it wasn't tripped. removed the fuel line and cycled the key and no gas was coming from the filter. Check behind the filter and gas isn't getting to the fuel filter. I did notice that when i try cranking it, all 4 lights stay on, but the oil light blinks twice before returning to solid color like the other 4 lights. Any idea?
    Pull the connector off the fuel pump and check for hot when the ignition key is turned. No light neans no juice. Good luck.
      Maybe you bumped the fuel pump connector under the back seat. Look under the carpet and you will see what I mean.
      -Bryant
        getting only 8volts at the hot connector of the fuel pump. But even with low voltage, wouldnt a little bit of fuel get through the lines, maybe not enough pressure to push past the filter, but before the filter maybe?
          Check your ENGINE fuse
            15 amp in-line fuse link adjacent to the steering wheel, is clean, no burn marks, no evidence of it being blown.
              Wrong fuse. I believe the ENGINE fuse in the fuse block is a red 10 amp fuse.
                Sorry, i was looking at the wrong fuse reading the wrong side of the fuse, yes, its a red, 10 amp fuse, and same as the last fuse, no burn marks, all is well fuse wise.
                  bad ground? corroded?
                  -Bryant
                    i had originally thought that also, so before posting i did clean all grounds in the engine bay around, found 8 of them discluding the battery terminal ground. even with a bad ground, it wouldn't randomly not work within 10 minutes, i wouldn't think at least.
                      I once had a no start issue with low voltage to the fuel pump like that.... My problem was the fuel pump relay went bad
                      Maybe by pure coincidence your relay went bad?
                        I've only been able to find the main relay for the entire card, next to the driver ( american ) side headlamp harness. Where is the fuel pump relay? ( not in the engine bay either, i've looked inside and out for the relay, and just can't find it. .. apparently its in the one place i havent looked, but i cant seem to think of any more hiding spots. its a 91 GL
                          It's up under the dash on the drivers side, there's a few relays there actually and I can't remember off the top of my head which one is the fuel pump relay
                            Well ill test them all at that location. Do you remember the continuity for the relays there?
                              If my festiva was more accessible right now (being used as temporary storage for other stuff which got stacked around my car) I'd get you a pic of the connector
                              My festiva has a custom circuit powering the fuel pump and no longer has the stock relay lol
