There's a small piece of hose running between a metal coolant line and to the motor that is leaking antifreeze. Anyone know what size of hose this would be? I forgot to grab it before I came to work, and I really need to pick a new one up before I go home.
Antifreeze leak
The little hose by this connector right?ON an 89 it is listed as 1/4 diameter.That is inside,outside is larger.IMG_20141201_142252.jpg
Go to the auto parts store or look it up on Rock Auto.
What you want to get is a coolant bypass hose for a Mazda 323 with a 1.6.
I just looked it up for model year 1991.
This will be the correct bend. Trim to fit for length.
Problem with using a straight chuck of hose is the good possibility of it kinking.
Agreed! Don't use a straight chunk of hose, it will kink closed. Personal experience...Originally posted by lessersivad View Post
Problem with using a straight chuck of hose is the good possibility of it kinking.The Festiva Store
Exactly what I needed. Thanks, fellas. Got it all put on, but I think I may have put my radiator cap back on slightly crooked, as I'm still getting a little bit of a leak. I really hope that's what it is, anyway! The money I'm shelling out for other people's cars for back and forth to work would be enough to drive around for weeks in my Festy!Originally posted by lessersivad View PostGo to the auto parts store or look it up on Rock Auto.
