I came across a tow bar that was made for Festivas and I have used it many times on 90 to 93 models over the years and it has worked perfectly. Now that I am trying to tow my just aquired 1989 Festiva, I noticed that the front 'tow-brackets' are different. The newer Festivas have 2 slots and the 1989 Festiva has only one slot - in the rear, that older Festiva doesn't even have slots, it just has a hooked shape bracket.
My Festiva tow bar uses two bolts on each side that go through each slot. I'm wondering if I can get away with hooking up my tow-bar in that 1989 using just the one slot. It might be flimsy but as long as it don't hit the ground I guess it would work...any one try this before? Also, one thing of importance: I didn't check to see if the width of the front brackets are the same between the early and late models.
