My festiva was sitting for a while about 2-3 weeks and I was trying to sort out my headlamp issue and so I decided to start up the festiva and check everything to make sure everything was going fine. I started it and now it seems the engine is knocking. Checked the oil and added some, but still knocking. I am thinking its a lifter it is coming from the right side of the engine. It did seem like it was going to clear up when the engine warmed up a bit, but then resumed at the same amount of noise. I was going to pull the valve cover off to check it out but after I pulled the intake hose off a bunch of oil came out from it. I figured I would ask about it before I got any farther. Could the engine be ready to blow? Arguing with myself if it would be worth pulling an engine for it.
Maybe some thicker oil (20w-40)? Friend of mine put that in his old 60's f100 to stop a knock and it worked.
