computer will not reset on obd II
  • computer will not reset on obd II
    on my 98 blazwe with v6 the following monitors will not rest and are incomplete even after many miles of highway and city driving: the montors are as follows, egr, catalist,evap and now the oxegen monitors and there are no trouble codes or pending trouble codes present and i am really stumpes about this after many miles of highway friving and city driving and i even disconected the battary and started over again with the same resuts and any help will be welcomed and than you all.
    For any monitor to run, all the "enabling criteria" must be met for that particular vehicle. You would have to know the specific requirements to be sure if the driving conditions were met, regardless of mileage. The O2 sensors are required for the monitors you have listed as not running, and are tested before the others. They have to be in good condition and their heaters have to be good as well or the other monitors will not run. Also, out of range fuel trim or ECT signals and too many misfires may prevent those monitors from running, as well as pending codes which do not set the CEL.
      I threw my computer away. I can sleep now. Isn't it anazing that a carb car doesn't need a computer to run?
