Door hinge bushings
dont mind... found the hinges at fourgreen. better deal for new ones than restore 20+ years old hinges....Attached Files
I adjusted my drivers door lock and striker last week. I don't know why I never adjusted it before. The door can now close with the lightest of pressure.
I will have to learn not to slam it anymore. Let us know if new hinges make a difference after you install them. Also, tell us what other parts you buy from them. Good luck.
I replaced the two vents on either side of the back hatch but it made no difference. I loosened the three door lock and the two screws on the striker, then shut and opened the door a couple of times, then tightened the screws.Last edited by bravekozak; 01-07-2015, 08:24 PM.
Will do, I bought several things from them, still waiting though since some of the parts had to be send from Korea to my address in Miami and then to Costa Rica....Originally posted by bravekozak View PostI adjusted my drivers door lock and striker last week. I don't know why I never adjusted it before. The door can now close with the lightest of pressure.
I will have to learn not to slam it anymore. Let us know if new hinges make a difference after you install them. Also, tell us what other parts you buy from them. Good luck.Last edited by Fordverde; 01-08-2015, 08:23 PM.
