The newest Festiva that I got had all kinds of hotwiring done to it so I tried my best to get it back to it's original state. The guy has a push button connected to the each place on the starter and a battery cable goes directly from the positive to the starter. There was all kinds of shananagins going on at the fusable link terminal that I shouldn't try to describe.
Anyway I grabbed the original batter positive cable and hooked it up and noticed that the smaller wire seemed to be corroded and broken so I spliced and jumped it to the positive. I removed the push button wires and hooked up the normal positive terminal at the lower part of the harness to the batter bolt (the larger bolt). I then put normal (old style) fusable links (3 of them) into their place.
When I turned the key to the first position, things turned on but when I tried to start it ... all got quite and it didn't work. So I hooked up the push button and the car starts and runs fine but there's a few wrong and weird things going on. The lights are on all the time and when the car is totally off the lights won't come on. Also, the radiator fan is on all the time. The starter solenoid (small terminal at the starter) must not be getting juice when the key is turned on.
There also may be some weird wiring going on under the dash, I just haven't checked that yet. Any one know what's up here?
