Well, this is kinda a continuation of the Lord of Hesitation. Figured out i might not have a blown head gasket after all, I think after i put the water pump on, i put a timing belt on it and i think it is one tooth off
ops: . I know this makes them run like poopy :shock: and i am trying to figure out if it is off or not. There is 2 marks on the top gear (camshaft) but there arnt any marks on the crankshaft except 2 little holes. My question is how to figure out if both the gears are in the correct position. Any help would be greatly appreciated. Also, any info by tomarrow will be greatly GREATLY appreciated. :wink:
Thanks again
RJV
ops: . I know this makes them run like poopy :shock: and i am trying to figure out if it is off or not. There is 2 marks on the top gear (camshaft) but there arnt any marks on the crankshaft except 2 little holes. My question is how to figure out if both the gears are in the correct position. Any help would be greatly appreciated. Also, any info by tomarrow will be greatly GREATLY appreciated. :wink: Thanks again
RJV
Thanks so very much. Now help me dance in the closed thread
Now i did compression tests and pistons 1 and 3 were rly low. Took the head off and piston 3 has a 1 inch piece broke right off. Now I have to buy a piston, and 3 valves.. all because of my lack of knowledge. Well, my loss is hopefully your gain.
