I have a 1997 Go-4 Interceptor (metermaid trike) that has the same drive train as an Aspire. I'm currently having some issues and looking for some help. When I'm driving up inclines (with gas pedal at least half throttle open) my check engine light will come on. I did the flash code check and it is code 17. I had been meaning to replace my o2 sensor and fine got it swapped out. Unfortunately didn't change anything. When I'm going uphill on a highway, I get loud pinging and feels like engine is losing power. Once things flatten out pinging goes away and motor is peppy (light usually will go out).
I don't think it's an exhaust back pressure issue?
Past recent repairs include: new distributor, spark plugs o2 sensor, starter, fuel filter, fuel pump and evap seals, fuel hoses to the motor and gas cap.
I replaced the fuel filter as maintenance and the hoses as my trunk has a fairly strong fuel odor. Changing the fuel tank seals and hoses didn't rid the smell. I'm going to change out the hoses from the filler neck to the tank today.
Is it a safe guess that whatever is causing the strong odor might be a contributing factor to my hesitation and check light? When I changed the tank seals the internal fuel strainer didn't appear clogged?
Any ideas or helpful tips are greatly appreciated!
