Ok, so Im not getting any power what so ever. The dash lights will not come on. I haven't even got a chance to try to turn it over. I put in a for sure good battery, checked all the connections, Checked main power fuse, all good. I just put in the bp ecu so i swapped back to the festiva one to try that with no success. Is there anywhere else to look? It is pretty old out.
BP SWAP No power please help
My car did the same thing when the main power relay went out. It's on the drivers side inner fender, kinda behind the coolant tank. Metal housing relay with about a 6 inch wire coming out to a round plug. Usually has 1 10mm bolt holding it on-Greg
Redneck Engineer
FOTY - '09
Thread moved to the proper section
I'll see if I can get you a pic-Greg
Redneck Engineer
FOTY - '09
the wire I fried is visible and is in this plug with the black/red wire. That black/red wire is one of the wires that goes into the alternator plug.
Store your photos and videos online with secure storage from Photobucket. Available on iOS, Android and desktop. Securely backup your memories and sign up today!
Does anyone know where the fried wire ends up on the other end of the harness? any info or wisdom on the subject?
