Does it matter if I were to flip my brake booster upside down so I can have the Vacuum line in a less conspicuous spot?
Brake booster orientation???
I often wondered the same thing, I'd assume it would be ok to flip upside down
Vacuum is lighter than air. If you turn it upside down the vacuum will fall out.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Originally posted by TominMO View PostVacuum is lighter than air. If you turn it upside down the vacuum will fall out.~Nate
Current cars:
FOTY 2008 winner!
