pistons
  • pistons
    dose any one know if the piston and rods out of a 1994 aspire will fit the crank shaft in a 1989 festiva? the ends of the crank shaft are a different size
    What's the book say of journal grinds and stroke? Final comparison would be wrist pin to deck
      i dont even have a book to go by i trying to put the pistons.rods, and i want to use the aspire head on the festiva block the aspire block is busted and the weld weld wont seal it i may just have to find me another engine
        Use a micrometer.
          The Aspire and Festiva blocks are the same. The heads are different, but will work on either block.
          Dan
