Question
  • Question
    My car when I'm on the throttle it pulls to the left. When I'm off the gas it pulls to the right, but when I have someone in the passenger seat it drives perfectly. Any ideas?
    Got That Backward. Gas is right brake is left with a small vibration.
      Check sway bar bushings and lower control arms .
      Mine did something similar and it was the body to sway bar bushings
        Ok. Thanks for the input. I will be ordering it next paycheck.
          Mine did the same thing. Just tighten the nut on the front sway bar. I bet it backed off.
          06 Jeep Cherokee Overland
          95 Aspire (sold)
            Well last year I was told that they would have to be replaced but I did not expect it to effect it this much.
              The AutoZone part number is FA7211 for the bushings between the sway bar and the lower control arm. They are sold in pairs, each pair services one side. I definitely recommend ordering two pairs and doing both sides at once.
              No festiva for me ATM...
                ^ All the above
                Dan
                  I wish I would have known about that when I had mine ripped apart.
                  95 Aspire (sold)
                    It's the sway bar to frame bushings. Thinking about energy suspension and having a friend at work welding the front hole to just let the bolt go through.
