I did a timing belt and water pump, car turned over when it died on side of the road. Now when I got all done and went to start it NOTHING, radio doesnt work, no dash lights, no blinkers, no interior lights that are weirdly enough wired in on toggle but maybe they wired it through a factory circuit. I have charged a new battery because the one that was in it reads at .05 volts and my smart charger wouldn't charge it
. The only thing I can get to work is the headlights, I checked the fusible link under the seat between the battery and the front and those are good as well as the three fuses in the engine bay, I switched the headlight one out with the main to confirm it worked, nothing still. I am at a loss and was not at all prepared for this, starting to feel like I should of left this to a mechanic.
