Well it started again today" 90 L 5 speed " and got worse the farther I drove from home .
5 th gear @ 55 mph it just like I turned the key off , I can press down on the gas pedal and nothing , then as it slows a little ,it's just like I turned the key back on ????????
Now also the check engine light started coming on today also , on our little trip tonight @ 55 steady in 5 th the light came on , if I push the go pedal just a little or let off the pedal the light go's right off ?????
If I leave the car in 4th at the same speed 55 with the R's up the car does not do the shut off thing , or if it at a higher rpm in 5th it does not seen to do it .
This car done this very same thing some time ago and finally quit it ???
and it really does it when the wife is in the car , I really do not think the Festiva likes her :lol: :lol:
Poverty produces creativity
