Well I overheated the festiva, more then once mind you.
I know the head gasket is toast.
I read about a guy replacing the piston rings by just taking the oil pan off. So my question is this. Do I just fix the head gasket and get a valve job, or should I do the rings as well?
Also what are the chances the main bearings are bad from the overheating? It still sounds and runs fine but overheats very quickly.
Mileage says 104k but I highly doubt that is accurate. It did not smoke at all.
