So, I found out my head is cracked. Yay. I found an Aspire with an 80K engine in a junkyard. Can I take the head off it, swap in the internals from my 88 carby, and pop it in my Festiva?
Head Questions!!
Just use the Aspire head. It will work on the Festy block. The blocks are the same. IMO, the Aspire head is a better head, as it has roller rockers, which the Festy does not
Get the Aspire valve cover too. The head and VC have a different shape where the VC mounts to head.
Order Aspire VC gasket for the VC.
I found that out when I put an Aspire engine in my 92. I had ordered a Festy gasket...and well, it didn't fit! lol
Took the gasket back, got an Aspire gasket and then it was all good!Last edited by drddan; 02-14-2015, 09:03 AM.Dan
Originally posted by robbylockisme View PostBut isn't the camshaft different on the aspire head?
An engine in an Aspire IS a Festiva block with an Aspire head. :mrgreen:
What I am saying is why swap internals? The Aspire is better, but both ways will workLast edited by drddan; 02-15-2015, 03:48 AM.Dan
Originally posted by drddan View PostYes! That is what I said in my post. Use the WHOLE Aspire head. The Aspire cam is in the Aspire head, with the Aspire roller rockers, all contained in one unit. It all works. Unbolt Aspire head, bolt on the Festy engine. All the differences are in the head itself. The Aspire head will bolt and function perfectly on the Festy block. Roller rockers are way better than non roller. Probably better mpg and maybe, a 1/2 pound of power too! lol
I believe the Aspire cam does not have the fuel pump lobe. If so, you would have to proceed as originally planned--use the Festy cam and rockers in the Aspire head, to retain the fuel pump lobe.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Originally posted by tooldude View PostThere is no fuel pump mounting boss for a mechanical pump on a fuel injected head. You will have to set up an electric fuel pump.Last edited by zoe60; 02-15-2015, 09:32 AM.
