Hello, I am looking for a replacement wheel bearing for my front passenger side. I called Ford, however, they don't make the parts anymore. Obviously. But I was told the part number is BR11. Can anyone confirm this? I believed it is a tapered wheel bearing, but not entirely certain.
Front Passenger Wheel Bearing
Hey I'm in Ft Wayne too. What side of town are you on. I may have seen you around town. I saw a red one I had not seen before a couple days ago out Southwest. What color is you Festiva. I had Napa on West Coliseum do my front bearings. The had the bearing and seals in stock. Machine shop pressed them in.'89L 110k mi. BP/G swapped
'90LX 68k mi. wrecked 12/14 RIP
'90 F250 4X4 108K mi.
'13 Kia Rio 5 LX 70k mi.
'18 Kia Soul 40k mi. Daily
'64 Studebaker Gran Turismo Hawk
'66 International Harvester pickup
Buy only Timken bearings. Any others will not lastDan
Timken- standard stock in any McParts store
Don't forget inner and outer seals, as well as disc brake bearing grease. Don't misplace the spacer.. There's a good picto-guide floating around here.Last edited by crazyrog17; 02-18-2015, 04:40 PM.-Zack
Front bearings for the Festiva are not sealed no matter the color of your car. There are two sets of #11 bearings in each hub along with inner and outer seals.
IanIan
I just recently changed mine got them from O'Reillys and having no issues at all with them.1990 Red Festiva STOCK "pregnant roller skate"
1989 Yellow Festiva BP swap "Freebird"
2007 Ford F150 "black sunshine" full exhaust with x-pipe. K&N intake. Headman Headers.
2001 Honda accord SOLD lots of goodies done suicide doors lowered 20 inch rims
2005 Ford F250 6.0 Turbo Diesel "swamprat" 4 inch lift, 4 inch mbrp exhaust, egr delete, glowshift pillar gauges.
1994 Ford F150 5.0 Completely stock.
did you make sure you took the outer seal off before took the old ones out my seal was so worn down it was hard to see and are you using the bearing tool to punch them in it also helps if you clean it up really good then put a thin layer of grease if you still cant get them to fit take a caliper to them and see if they really are the wrong size also a picture whould help.88 L carb'ed (when up in flames of glory)(deceased) 4spd
89 L carb'ed (died on the operating table (rust))(deceased) 5spd
93 gl FI (sold) automagical
89 lx FI megasquirted "luna" b6D+t (186hp 209ftlbs)
88 L carbFI megasquirted zombie car
O'Reilly doesn't make bearings their house brand is made by who knows and I do not know what brands they carry.I do know that the spacer in the front is to maintain proper preload on the bearings and they come in different thicknesses to compensate for manufacturing differences in the housings anyway long story boring useing quality name brand bearings gives you better odds of having proper preload only because you have a better chance of having a bearing manufactured to tighter tolerances,just like rebuilding a differential . Using name brand bearings is just a little safer unless you are going to check and reshim.30 + Vehicle projects right now.7 Festiva/Mazda 10 GM IDK how many others,hope that helps explain all the stupid questions/shortcuts/interchanges etc. trying to liquidate so I concentrate on the good ones. Goal finish 1 amonth using as much stuff as I already have accumulated.
No cheif, cheap bearings will fail in 10k miles or less, the only ones last are timkin. Whether you mic the knuckles and make a new spacer or use the old or you crazy expensive grease. Only use Timken unless you enjoy doing wheel bearings.
I have never had an issue with oreilly bearings. My truck has had 2 on it from them for about 60000 miles and I never done anything to them but drive it.1990 Red Festiva STOCK "pregnant roller skate"
I have not found house brand bearings off size but occasionally things can happen that QC does not catch. I have found unacceptable heat treating. Before installing a bearing put it on a vise and used a center punch and a hammer to dimple the race, inner and outer. DO wrap a rag around the end of the punch as fragments of punch should come apart from the tip. The bearing should not have a dimple at all. If it does it is not hardened enough for acceptable service even with red line grease. If it breaks then the hardening went to deep and destroyed the toughness of the bearing. It would be fine in service until you come to Oregon and hit a chuck hole on one of our city streets. Bam..broken bearing. If the yokohama 12's don't go first lol
Timken has been closing plants and moving them to India and China. German FAG and Japanese NSK are still pretty good. If the Timken still says something besides China it should be good stuff.
Don't tell me your center punch is made in China???Last edited by Movin; 02-22-2015, 12:27 PM.Reflex paint by Langeman...Lifted...Tow Rig
