My Festiva all of a sudden doesn't want to idle any more. I runs fine down the road but it just doesn't want to idle.
I turned up the idle speed for now just so I can continue driving it (1500 - 2000 RPMs).
Things I've tried so far:
Spraying out the carb with carb cleaner (just what I can get to with it on the car)
Running Seafoam through 2 tanks of gas
Checked for vacuum leaks - none found
Changed fuel filter
Is there some valve or solenoid that controls the mixture at idle? I've had problems with the deceleration valve sticking before on this car and my other 88 Festiva, but that doesn't cause idling issues.
I thought about removing the idle mixture screw and flushing it out. But couldn't figure out how to remove the cover over the screw.
No, I'm not interested in converting this car to a Weber right now. Nor do I won't to go through the hassle to convert it to EFI.
Thanks in advance for the help!
Jeff
Changed fuel filter
Jeff
