Rear strut assembly
  • Rear strut assembly
    I have a 91 Festiva L.
    I'm a little confused with my rear strut upper mounts. There are 2 rubber bushings. Under the bottom one, there is a cup shaped piece. Which way does it go?
    Thanks
    BP powered 91 Festiva L
    -FMS springs, GR2 struts, Toyo T1R 195/45/14 on Swift GT alloys
    -Trunk mounted gel battery
    -Suzuki Swift GT seats, Grant GT steering wheel, auto-locks
    -Blaupunkt Melbourne deck with Bluetooth, sealed single 12" sub
    The cup should face down with the rubber sitting on top of it. In other words, if the hole in the middle was plugged and you filled it with water, you would want to turn it over and pour the water out and itstall it in that position.
    You gonna race that thing?
      great, thanks. I finally got it right!
