So I did the timing belt and outer seal cuz something was leaking. when I was trying to pull the seal out and my poker slipped back in the direction of this hole i found in the bore. I'm not sure if my tool caused the hole or if it was there already.I'll take a picture of it when I can. Like I said its at like the 7 o'clock area of the outer bore of the oil pump Ruhr behind where the oil seal sets. Has anyone else seen this hole or did I cause it?
I didn't have anything the perfect size to push it in so I used a big flat head with a towel over the tip and gently tapped the new seal in. I also did the cam seal and oil pan gasket so its not those.
Also the instructions say to torque the crank bolt to 127 and the book says like 81 I think just curious how tight it is supposed to be?
thanks
thanks
