Buzzing noise
  • Buzzing noise
    I have a 1993 festiva and when my key is in the ignition it makes a loud buzzing noise until I remove the key! anty1yone know the problem and how to fix it? thanks in advance!
    Does it buzz when the car is running and the door is closed?
      Unplug the buzzer
        Yes it runs with car running and the door closed, and Idk where the buzzer is to unplug it
          It stops as soon as you take the key out it stops
            It's been a long time but I remember leaving the key in, door open so the buzzer was going off, then reaching up under the dash and just feeling for which "relay" was slightly vibrating, unplugged it and got the right one
            Worse case if you unplug the wrong one, just plug it back in, trial and error
              Thanks I will definitely try it
                You have a blown fuse. Fuse all the way to the right. replace fuse, buzz goes away.
                Chad
