Proper cold weather and a tricky problem you get all the fun!!
Festy down
UghOriginally posted by Movin View PostProper cold weather and a tricky problem you get all the fun!!
Still cold tomorrow. I will bear thru it and try to pinpoint the issueLast edited by drddan; 02-27-2015, 10:40 PM.Dan
Resolution!
Festy is running! I feel so dumb! It wasn't fuel related at all.
I went out this morning and tested pump and relay. All checked good! So I was just looking at the engine and I see the coil wire on disty side was laying loose down on the tranny. The wire inside the coil wire had disintegrated. Well, that might be the problem!
I cut and re-attached the metal contact onto the coil wire, to check if it was for sure the only issue, and it fired right up.
I was getting spark last weekend while trouble shooting? It was orange though, not blue. How did I get spark without a coil wire is beyond me. Anyway, new wires are waiting for me to pick them up and life is good again...sheesh!Last edited by drddan; 03-07-2015, 12:33 PM.Dan
