dash light question
  • dash light question
    ok so I picked this festy up about a month ago now. I have been kinda going through it. I noticed a couple things. One may be correct for the car the other im pretty sure something is up lol.
    1st
    when I get in the car and press the brake the buzzer comes on until the car cranks
    2nd
    at night when driving with the lights on I have no dash lights until I press the brake. when I let off the brake they go off
    1990 festiva l (747 the jumbo jet) (b6t & g box)
    What year is the car?
    Were in Tn are you?
    David
      Were in Tn are you?
      David
      just up the road from you lol. Henderson tn.
      1990
        1st -When you say buzzer, is it the "lights on" warning with the tach cluster? I found that a cheapo LED style brake/tail light caused that with the "lights on" warning.
        I don't think this would have any effect on your 2nd problem.
        "Wenona"-89L parts car
          the brake buzzer thing will do it with lights on or off. I tried that lol. I agree I think they are separate issues
            Do you have the tach cluster? With mine it didn't matter if the lights were on, the cheapo LED lit the whole light(all LEDs) whether on as tail light or brake light and the lights on warning saw it as a light on either way. So when the brake lights came on it alarmed the same as the switch being left on. If you don't have the tach cluster, none of this applies anyway.
              Here we go again. Is your radio illumination on continuously or does it go off when you let you let off the brake?
              If it stays on, then I would replace your dimmer switch.
              The radio has a separate ground than the instrument lights. The instrument lights ground through the dimmer switch.
              They both share the same feed from the TAIL fuse.
                Yes it is the tach cluster. Idk about the radio part because there wasn't a radio in it when I got it lol
