Power windows to non equipped car
  • Power windows to non equipped car
    I am retrofitting the OE Pwr mirrors & switch to my 98 L that had NO provision/harness for any of the LX options :cry_smile:
    where can I find the pin-out & wire color codes to connect & make functional my setup
    I found all that I needed from a JY 91 L except the connector to the back of the directional switch (someone had already scrounged it. )ty1
    What year for sure?
      miss-typed 89 MY
        Been fairly frustrated by searches here...LOTS of threads with identical questions, (:how do I hook up my power mirrors?) always a few clarifying quip's (:use plugs in door!, or :found only in MY's equipped.. ect), but rarely cohesive solutions.
        Sounds like the transition in MY from 88-89 and dependent on trim level will determine IF the harness /pigtails that would support the addition will be present. Ok. Mine is an 89 MY L trim but NO accessory harness's exist (no, R. hatch light, no wiper/washer, power mirrors ect).
        Will a Haynes of Chilton manual have the switch pin-out's & wire color codes I will need (I have neither)?
        Does anyone have quick access to scan & post those if so ?
        Thanks again
          this is from a 1989 EVTM.
            The power mirror plugs and wiring should be part of the 89 wiring harness. Look again.
              Awesome much appreciated!
              EVTM?
                Electrical Vacuum and Troubleshooting Manual
                Just jook for the connector behind the large blank cap with those wire colors.
                  Nope no such luck. Unless a PO cut them out (?) this one doesn't have them
