Are the dimensions the same for F.I. and carby shafts so that they are interchangeable as they appear to be? - and is there a known source new rocker arms and shafts?
Rocker Arm Shafts
according to ford parts book they are identical except for using the adjusting nut on the carb rocker. also the shafts for intake and exh have different #s.
shafts, rockers, and spring spacers are all available new OEM from GREEN SALES and other obsolete inventory but it might be cheaper from parts store if you can find equivalents
I agree, and wish there were roller rockers with solid lifters. Still need to get around to making some of those. Can't keep a Festiva running long enough, though.Originally posted by Studebaker View PostAspire roller rockers are the way to go with todays oils.
DavidAny difference that makes no difference is no difference.
Thanks for that information! Is there a master parts number listing available somewhere? I'm trying to accumulate the numbers I see on the site.Originally posted by F3BZ View Postintake shaft - E8GZ6563A. exh shaft - E8GZ6563B. cylinder 1 & 2 intake/exh rocker arm - E8GZ6564. 3 & 4 intake/exh rocker arm - E8GZ6564B. spring spacers - E7GZ6587A.When I'm good I'm very, very good and when I'm bad I'm HORRID.
