Auto seatbelt help
  • Auto seatbelt help
    how hard is it to fix the automatic seatbelts in the festiva? I love the automatic seatbelts! My GL's belts are almost to where it doesn't work anymore.... I have to open and close the door 2-3 time somtime to get it to open to let me out but only on the driver's side... common problem for theis cars as they get old?
    Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
    Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
    Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has
    it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
    Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
    TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to
    bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
    '94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
    SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
    R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
    R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
    R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
    R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
    R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
    Might want to check your door switch. Sounds like it's dirty or corroded.
    Jerry
    Team Lightning
    Owner of Team Lightning
    93 L Lightning. BP
      and that's the bush switch at the bottom of door jam? the dome light only works in the on position as well...
        General forum isn't a catch all section
        Thread moved
          No. The push switch on the body is for the dome light only. The door latches have a door ajar sensor wired into the latch. Make sure your latch is clean.
          I removed my auto belts and substituted manual belts. I wired my door ajar sensors into my Viper power lock/alarm system. doors automatically lock five seconds after starting engine/immediately unlock after turning ignition off + alarm goes off if door is opened without using the Viper remote to unlock the doors and disarm the vehicle. I knew those sensors were good for something.
            ok i know what your talking about... will clean them...
              Bravekozak, how do you clean the door latch.
              Thanks
              David
                Brake cleaner I'd assume.
                  I ha e the problem that I have to open/close/slam the door - not for the latch to catch, the latch is perfect- the seat belt just doesn't go. Where is the sensor and would I have fudged it when we'll lubing the door latch?
                    WD-40. It's a Water Dispersant which is good if there is moisture in there causing a short.
                      I sprayed Liquid Wrench Lock and Hinge Dry Lube. Which is odd as it looked wet to me. - Is this an awe-Dang! moment? Did I screw something up or will just enough WD40 dry it up?
                        I have a dry graphite spray which is wet going on. I suspect the graphite is in solution to carry it into crevices and other tight places with a volatile liquid which evaporates fairly quickly leaving the graphite behind.
