Well today I yanked the low mileage steering rack out of the 88LX with the boots still intact to install into my 91'.
Got the old rack out of my 91' since the bushings were shot and so were the boots, and got 88 rack up and in place, and the tie-rods attached to the knuckles, but can't for the life of me to get the splined end of the steering rack to slide into the steering u-joint. Is there some kinda trick people know? Also trying to do this alone is a absolute female dog. Also doesn't help that the steel racks only have 2 little notches for the pinch bolt that I have to try and line up, while the aluminium racks the notch goes around the entire shaft.
I've already removed the lower 12mm bolt inside the car to let it wiggle around more so I can try and get it lined up, but still nogo. Should I just unbolt the brackets completely, and have someone underneath with a jack move the rack around while I try to get it to line up properly from the top?
Also why did I choose to do this AFTER I lent my only backup car to my brother that was in need of a vehicle? lol
