Changing Rocker Arms
  • Changing Rocker Arms
    Can the rockers with hydraulic lifters be run on the cam from the carby or is there any difference in the geometry that could cause problems? I'm not finding anything on this.
    i can't say if it will work but there are 3 different cams so there must be something different. be interesting to know the lift/duration specs for each.
    1988/89 MT - E8BZ6250A
    1989 ATX - E9BZ6250A
    1990/93 MT/ATX - F1BZ6250A
