I am getting the recently purchased 93 Festiva ready for Westiva and then onto Madness. I noticed the O2 wire had been cut off so I replaced the O2 sensor with a new Denso O2 sensor. The idle speed is 1600 rpm and will not slow down even though the idle screw is turned down all the way.
I took the car out on the highway for the first time this evening and the CEL came on. I read the codes and have code 08 and code 15.
How do I slow the idle down?
New O2 sensor bad? VAF bad also?
Thanks.
Thanks.
