Are the head swappable? I heard there's different cam sizes but since my car is a 93 i figured they would be compatable. Should i go back and check the year? This is the same car i pulled the steering rack and and a knuckle off of.
pulled a head off a automatic aspire and forgot to check the year. i have a 93 festy
All Festiva/Aspire heads are swappable. You just need to use the same cam and lifters from one head. Festy carbys had manually-adjustable lifters, Festy EFI had hydraulic lifters; Aspire EFI had roller rockers. They all use the same head gasket too BTW.Last edited by TominMO; 05-15-2015, 03:17 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Rockers need to match the cam, festy cam works fine in an aspire and vice versaLast edited by zoom zoom; 05-16-2015, 02:08 AM.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
The complete head is swappable. The cams can be swapped also, BUT only if you keep all the components together i.e. cam and rockers from head "A" can be swapped into head "B".Originally posted by 2jzkilla View PostAre the head swappable? I heard there's different cam sizes but since my car is a 93 i figured they would be compatable. Should i go back and check the year? This is the same car i pulled the steering rack and and a knuckle off of.
